Old 03-29-2008, 06:18 PM
chevyk1500geek's Avatar
chevyk1500geek chevyk1500geek is offline
Question Transmission Problems! HELP!
ok, so my dad owns a 1988 chevy k1500 cheyenne that was purchased in 1987. This truck has an automatic transmission which has two drive gears, highlited and un highlited. SO several years ago, the highlighted one started doing a short high pitched grind at about 15mph, then it would stop(the noise that is). And the other day i was driving it, and in the unhighlited gear, i took off from a stop, and that gear grinded very shortly. When we got home, we switched positions and my dad tested the different gears(P R N (D) D 2 1) and the highlighted drive gear is now acting like a neutral gear! has anyone heard of this or had similar experiences? does anyone know whats going on?
Old 03-31-2008, 01:27 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: grinding transmission? or what?
it is a 700r4 if it has two D positions IE it is a 4 speed overdrive automatic
are you sure the grinding is not from the automatic front hubs if they are still on the truck ? they are known for failing and making grinding and such noises
the transmission itself wouldnt make this kind of noise but the transfer case can
synchronizer in it may be worn
it happens
used good cases can be picked up for dirt cheap
esepcially these 208 and 231 ones
very common they are
or it can be fixed for pretty cheap as well
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 03-31-2008, 06:31 PM
what do u mean by the front auto sensors? Is this a common prblm?
