| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Rough Idle
I've been having a rough idle on my '96 Mustang 5 Speed V6. I got oil changed, fuel filter changed, spark plugs & wires changed and cleaned the IAC.
Now here's a question. The CEL is on. I went to autozone to have them read it, the error was P0300 (Clynider Misfire). I changed spark plugs and wires at that time. Now here's the thing I noticed, before changing the plugs and wires, clyinder 4 if I removed the wire from the coil the engine wouldn't change at all. It would run the same as oppose to say removing the wire from clyinder 5. But I can't remember off the top of my head how 1-3 did. But now I notice that 1-3 when removing the wire don't have really any effect on the motor and the RPMS. But removing any from 4-6 wire, you'll notice a change. I've heard something about the '96 having a dual coil? Not sure if that's right. But if 1-3 are sparking but not causing a difference could it be the coil? http://www.autozone.com/selectedZip,.../selectZip.htm Should I buy one just in case? Could the ignition coil be bad, even though 1-3 are sparking? Thanks, James |
Re: Rough Idle
Sounds to me like it could be the coil.
1969 Cougar 357w & TKO - 475hp |
Re: Rough Idle
Re: Rough Idle
They make a test light that you clip on the plug and the plug wire on the other end. Check each coil with one of these. You can see them blink.
Available at a parts store. Use a stethoscope and listen to each injector. Available at a parts store. Parts cost big money try to find the problem before buying. |
