Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 03-29-2008, 10:35 AM
stewy1971 stewy1971 is offline
someone help me please
I have a 92 4wd van, won't turn over it makes one click, I changed the solionid, have good battery charge & good connections, is there anything to check before changing starter motor?
Old 03-29-2008, 08:44 PM
rhandwor rhandwor is offline
Re: someone help me please
Use a DVOM you need at least 11 volts at the terminal where the cable bolts on to the starter. This is when trying to start the vehicle. Use jack stands so you will be ok if it starts. If you have this buy a rebuild starter.
Old 09-18-2008, 11:01 AM
55daytonaman 55daytonaman is offline
Stewie ...Donnie Stewart? anyway I am Gary Stratton and if it was mine I would turn the engine over by hand to make sure it isn't seized...do this by turning a pipe wrench sideways on the bottom front pulley of your engine...sometimes you can just grab the belt and turn it..if you can turn it ..even a little ...then change the starter and you will be good.
