Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-29-2008, 07:31 AM
johnhutchinsusa johnhutchinsusa is offline
Oil blown out remdiation
97 Spyder with 2L turbo, had filler cap left loose/off after topping oil.
Blew out 2-3 quarts.
Resulting in
lifter noise, (quieting down), leaking valve cover (need gasket) and the big question.
Oil pressure runs near low range mark at driving rpms and below normal range at idle.
I know folks on this forum have seen it all,so what are your ideas?
Thamks!
John
Old 03-29-2008, 01:18 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Oil blown out remdiation
Well, you did fill it back up right? From what I remember, my oil pressure runs below the mark at idle, but I also think its a healthy bit above the normal line when I am cruising. Honestly though, I dont think you have anything to worry about.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-29-2008, 07:40 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
How did you loose 2-3 quarts of oil before you noticed it? Thats an ass of oil blowing all over a hot motor. It should have been smoking so bad you would be able to see the road. The motor should be fine though but keep an eye on it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-30-2008, 09:36 AM
ned032002's Avatar
ned032002 ned032002 is offline
I forgot to put the 710 cap back on after filling the oil once and I didn't get very far before I could smell hot oil so I pulled over immediately and I had only lost about 1/2 a quart. So how far did you go? Did you get on the highway or something?
