Old 03-28-2008, 05:23 PM
beads beads is offline
94 taurus ABS warning light on
My daughter hit a pot hole large enough to blow out the front rt tire. Since then the yellow ABS and red brake "idiot" lights have been on. Any suggestions on what to check would be appreciated.
Old 03-28-2008, 09:29 PM
03impala9c1 03impala9c1 is offline
Re: 94 taurus ABS warning light on
my first thoughts would be to check your wheel speed sensors and the wiring to them on that side make sure they are connected and/or you may have abad wheel speed sensor now
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 03-28-2008, 10:01 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Yep, and inspect the tone ring on the halfshaft for cracks or missing teeth.
You could also have the ABS codes read using an ABS scan tool. A standard engine scan tool will not be able to read the ABS codes.
-Rod
Old 03-28-2008, 10:17 PM
mikeemon's Avatar
mikeemon mikeemon is offline
If the car is obd1 with the data connector under the hood, which I believe it is, There should be 2 data connectors under the hood at the firewall. 1 for engine system and another for the abs system. These codes can be retrieved with an older style obd1 ford code scanner or with a test light in a manner similar to retrieving engine codes.
