Old 03-28-2008, 05:13 PM
Micro1 Micro1 is offline
98 GTP starts then stalls?
For the most part of last year up until now, I've been having the same problem that I see alot of people have posted on here and it's when the Tac drops to 0 and the TCS shuts off. Last year when I search for what the problem was I was told it was probably the Crank Position Sensor. I never had it checked out because it would reset itself after I restarted the car.
I have had any starting problems until the other day I drove my car to the Doc's and when I went to start it up when I was leaving it started but it would stall after about 10 to 20 seconds.
I had it towed and my mechanic said he wasn't getting any readings of a back CPS.
I read where BNaylor said quote( Most crank sensor problems don't even generate DTCs.) Is a DTC a code that the mechanic would get when checking the sensors?
My mechanic said if it's a computer problem he's not going to be able to fix it. Should I just tell him to change the CPS and see if that fixes it. Or have him clean out the Throttle body, I read on here that might cause started problems too.
Thanks for your help
Micro
Old 03-28-2008, 06:41 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 98 GTP starts then stalls?
Since you have a '98 GTP with the L67 engine and symptoms where it dies after 10-20 seconds did you try the fuel pump resistor bypass? See link below.
http://www.automotiveforums.com/vbul...d.php?t=658282
Timeslip 08/12/06
AF Community Guidelines
Old 03-29-2008, 03:35 AM
Thank you very much, I will call my mechanic on Monday and tell him to order the resistor kit.
Micro
Old 03-29-2008, 07:58 AM
BNaylor's Avatar
Just so we know for sure did you run the bypass at the fuel pump speed control relay in the procedure and is it working now?
Timeslip 08/12/06
Old 03-29-2008, 01:36 PM
I don't have my car, it's at the mechanics, had to get it towed there. Won't be able to contact him until Monday.
Micro
