Old 03-28-2008, 04:50 PM
truck150 truck150 is offline
p1870 code what does it mean?
my reader says trans component slipping what does that mean please help me i just bought the truck it is a 96 half ton
Old 03-28-2008, 06:13 PM
777stickman 777stickman is offline
Re: p1870 code what does it mean?
From my '98 C/K GM manual.
"Internal transmission failures could set a DTC P1870"
Basically that means there is slippage in your tranny that the computer is sensing.
1st thing to look at is the TCC
Say your going 60 MPH and give it some moderate gas, the tach should show an increase in RPM's as the speed increases. If it shows an RPM increase as soon as you hit the gas pedal then the TCC is faulty.
2nd thing is the 1-2 and the 2-3 solenoid valves.
Really only good way to diagnose this is with a good scanner that can access the tranny module in "real time".
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-28-2008, 07:55 PM
what is a tcc and where would i find it. Also when you say moderate gas how firm of a push do you mean? are you meaning to make it down shift or just enough to not make it down shift
Old 03-29-2008, 10:09 AM
TCC=Torque Converter Clutch.
Just enough throttle to increase speed without downshifting from 4th gear at 60 mph.
All items listed previously are internal in the tranny.
As stated, a high end scan tool is needed to access the tranny computer module for proper diagnostics.
57 Chevy 210
