Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-28-2008, 10:28 AM
jveik jveik is offline
383 worries
ok, basically, i need to make sure my oil pump pickup will work well on my 383
Im thinking of getting a slightly deeper oil pan with a windage tray either built in to the pan or one specifically for bolting onto modified main studs. my basic question is if i can use a stock pickup tube with my mellings high volume pump. i am worried that maybe the tube wont go down deep enough into the pan to be always supplied with oil? anyone here have any 383 experience under thier belt?
Old 03-28-2008, 11:04 AM
maxwedge maxwedge is offline
A990 racer
Re: 383 worries
Measure from the block rail to the bottom of the pick up, get your pan and gaskets together and check the depth from the pan rail to the bottom of the pan where the pick up will be, there should be about 3/8" area under the pick up.
Old 03-28-2008, 11:35 AM
Re: 383 worries
cool. thanks for the info
Old 04-05-2008, 07:08 PM
j cAT j cAT is offline
Re: 383 worries
the deeper pan gives you more capacity... this will also help cool the oil better. using a high volume pump with the oil pump pick up off the bottom of the pan would be and advantange as the sludge buildup will be less of a problem for pump.....
