Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-28-2008, 01:11 AM
fixrup fixrup is offline
trans help please
i have ben reading about all the stuff on the p1870 code. and i am more confused. should i get a shift enhanser, replace the valve, take it to the shop???? i have a 96 tahoe with a harsh 1st to 2nd shift no outher problems. i understand that the new 2000 and later valve bodies are rid of this problem (the valve body waring out and causing the valve to stick) so does anyone know if i can just swap the valve from anouther late model 4l60e into my 96 or is there any ideas to fix the prob.
Old 03-28-2008, 09:13 AM
Danielswan Danielswan is offline
Re: trans help please
you can get a reamer tool kit to enlarge the bore and buy the repair kit for it. they are available from many places. i bought mine from Best Brands LLC. they are on the net but they are also in my home town so it was easier to trust. if your carefull you should be able to do this fix.
Old 03-28-2008, 09:25 AM
maxwedge maxwedge is offline
A990 racer
Sonnax.com is a common supplier. It is a matter of the TCC valve in the valve body ( aluminum) wearing and causing a pressure loss during lock up, this can be a some what complicated job for a dyer without any mechanical backround, just some advice here.
Old 03-28-2008, 10:00 AM
i am an experienced mec but i work on equipment and of corse my 68 chevy pu in resto but not so much on transmissions. i just whant to make sure i understand all i need is the reamer and valve kit. thanks for the help
