Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-27-2008, 06:32 PM
way way is offline
Best Place for a Jack Stand
Usually whenever I've had to jack this car I used the k-frame or rear axle bar.
However now that I have to put the car on jack stands I'm not sure where to put the stands. Here's where the manual says the jack point is:
Sorry for the small letters. ( I hate Microsoft Paint )
As you can see, the 5 inch mark is in kind of an odd location and I'm not sure how the factory jack could be used there. You can make out one of the spot weld dimples just to the left. Should I just use a piece of 2 X 4 under there along the body seam? I don't want to screw up the sheet metal there if I can help it.
96 Geo Metro H/B 1.0 L, 5 sp, A/C 103K miles (165,762 KM)
96 Geo Metro LSi 1.0 L, 5 sp, 1025 miles (1649 KM)
91 Olds Ciera 2.5L 2 DR Auto
Old 03-28-2008, 08:53 PM
maxwedge maxwedge is offline
A990 racer
Re: Best Place for a Jack Stand
use the reinforced area where the bolt is.
Old 03-29-2008, 12:08 PM
way way is offline
Thanks Max
I should count my lucky stars I've never had a flat with this car. I put a piece of 2x4 diagonally across both the bolt and the raised seam with the jack under the bolt part. So far so good.
