Old 03-27-2008, 02:29 PM
jmesawitz's Avatar
jmesawitz jmesawitz is offline
Anneal PE ?
Any tips on how to anneal PE parts? My last effort involved holding it over a candle flame. It got red hot & discolored rather quickly. I think that it may have even shunk a bit. I had hoped to keep the parts metalic nature but had to paint it.
Old 03-27-2008, 04:28 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Anneal PE ?
Annealing metal will heat stain it- there's no way around it. For small (low thermal mass) parts like PE etchings or small (1/32") diameter brass wire, a candle flame is a perfectly good way of doing it.
PHOTOBUCKET SUCKS
Old 03-27-2008, 11:27 PM
Didymus Didymus is offline
Re: Anneal PE ?
Why do you want to anneal PE?
Ddms
Old 03-28-2008, 12:56 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Anneal PE ?
Ddms
Exactly. Plus some PE comes with a flash of nickel plate over it, there's no advantage to burning through that. Any piece of PE I ever had to bend always did so without a problem.
Bob
Old 03-28-2008, 02:19 PM
jmesawitz's Avatar
Re: Anneal PE ?
So here is the piece the was giving me problems. (rather a crappy representation of it for discussion purposes)
It is a flat PE piece that gets formed into a box but one panel of the box (red) has a concave surface. From MFH for FXX
I ended up dis assembling the PE to remove the part that needed bending and assembled the box minus this piece to start.
From there I really struggled putting the curve on the small piece without leaving a hard edge from my plyers. It would not budge trying to roll it around brass rod. It was suggested that I anneal the part to get it to bend easier.
Seems I should have left this one the parts tree.
Old 03-28-2008, 02:35 PM
klutz_100's Avatar
Re: Anneal PE ?
Just anneal it, bend it, glue it all together, paint it up and move on to your next part IMHO
Old 03-28-2008, 07:34 PM
Re: Anneal PE ?
Makes sense. (I didn't ask "Why in the world did you want to anneal PE?" I just wanted to know why you did it.)
I don't know any other way to get a smooth bend on a small piece of PE.
For that matter, I don't know how to keep scored and bent PE intact. It doesn't always break, but the odds seem to be about 50/50 that it will eventually fracture.
Ddms
Old 03-30-2008, 03:24 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Anneal PE ?
If I were you, I would have gently curled the red area by using a needle file, brush or anything round, then slowly bend two sides of the red area, and the rest.
Hiroaki Fukuda
