2000 Accord 4 cyl LX Front Brakes
Guys,
Doing a front brake job this weekend. In the caliper rubber bushings kit I got from Raybestos (rubber bushings fit over caliper pins) there are 2 O-rings and 4 rubber bushings. Do the two O-rinds go on the bottom caliper pins on each side .... if so where ? Thanks, AJ |
Re: 2000 Accord 4 cyl LX Front Brakes
well, my first guess would be on the brake line where it attaches to the caliper, If you didnt take them off, you probably dont need to put them on. never done a 2000 but this is true with about anything
Makes sense. I'll check.
Thanks, AJ |
I suggest you go to the Majestic Honda site and look up the parts breakout for your model. It will show all the parts that go with your brakes. You may have more parts then needed as some kits cover different models and the parts you question may be used on another model.
this is also very true.
