Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 03-27-2008, 06:52 AM
sonic51 sonic51 is offline
Unhappy 88 trooper not starting
well i have a 1988 isuzu trooper II FI 5 spd, there is no gas gauge so i tend to run out of gas every now and then :/ anyway now after putting a few gallons of fresh gasoline she wont start. I would really appreciate it if some one can help me with a diagram of some vacuum lines aswell i knoe there not connected correctly, thanks
Old 03-27-2008, 09:06 AM
rjer3's Avatar
rjer3 rjer3 is offline
Re: 88 trooper not starting
so it turns over and won't start? if thats the case then the fuel pump might be bad being you said you run out of gas every now and than. the pump picked up debris and got stuck you can probably tap it a few times to loosen it up ad try it again.
Old 05-05-2008, 07:54 PM
colopatironxv colopatironxv is offline
It might be the pump, see the gas in the tank keeps the pump cool, once you run lower than about 1/4 tank it gets warmer, and can burn out, or like rjer3 said pick up debris.
1994 Isuzu Trooper S 3.2l sohc 5spd = Awesome
