Old 03-26-2008, 06:52 PM
newyorker1 newyorker1 is offline
holy crap, ABS Codes...........
i just got my new abs code reader for my 2000 windstar and these are the code i just pulled from the van...
C1155
C1145
C1185
C1198
C1194
C1254
C1246
C1250
C1242
C1214
C1210
Can this be true? this is my first ford ad i am still learning this crap.. can i really get all these code at one time? Can i repair these myself or bring it to ford. all your help is greatful.
Old 03-26-2008, 07:50 PM
tartersauce tartersauce is offline
Re: holy crap, ABS Codes...........
Try a Reset then see what codes you pull.
Battery and Charging system ok?
puter connections? or Main connector.. Water in connector?
One is Pump failure and Nothing to do with a wheel pickup sounds more like its electrical.
Old 03-26-2008, 07:53 PM
try a reset? yes all is good otherwise.
Old 03-26-2008, 08:02 PM
Disconnect Neg battery few mins, Hit brake pedal once just to use any remaining voltage.. Your scanner may have a reset mode. Check fuses to ABS Under hood and inside.. In manual for Numbers..
Old 03-27-2008, 06:52 AM
tripletdaddy tripletdaddy is offline
So after the resets, what remains?
Old 03-27-2008, 07:18 AM
northern piper's Avatar
northern piper northern piper is offline
all'z I want t'know is, what kinda code reader do ya have that'll pic ABS codes??
Piper
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 03-27-2008, 07:47 AM
97windstar3.8 97windstar3.8 is offline
C1155
C1145
C1185
C1198
C1194
C1254
C1246
C1250
C1242
C1214
C1210
Whick ABS scaner you got? There should be a manual with it to explain each code.
If it was me, I will check each code first and re-set the ABS memory. Then run and aply break to caue NEW error code, then read new error code...
Finaly, you will now where is wrong.
I suffered these damn ABS error and did not get any way to read and explain them for a long time.
Beside buying expensive afternmarket ABS scaner or go to Ford dealor, Any one know any way to read these ABS error code ?
Evey one can benefit from this.
Old 03-27-2008, 09:06 AM
Piper
this one: Actron CP9449 ABS BrakeScan Diagnostic Scanner
got it at a real nice price too.
Old 03-27-2008, 11:18 PM
how much and where? What do they normally run?
Old 03-28-2008, 10:59 PM
http://www.actron.com/product_detail.php?pid=16349
go to ebay to price, sometimes cheeper.
Old 03-28-2008, 11:00 PM
i went to ebay for mine.
Old 03-30-2008, 08:29 PM
disconnected the neg and waited 10 min, reconnected and drove around, no abs light but the 11 codes are still there,
update: the light came on and when i turned the van off it didnt come back on, an hasent so far.
Old 03-30-2008, 09:10 PM
The codes are in history, and should be dropped after so many cycles, I think 50? Once you have so many good cycles with no codes it should be wiped clean.
Old 04-29-2008, 07:52 PM
they came back the codes, is the abs unit a one piece unit or two? can i get the abs unit rebuilt? thanks.
my neighbour across the street has the same year van and is having the same problem and the same codes.
Old 04-29-2008, 08:31 PM
rhandwor rhandwor is offline
Go to http://www.modulemaster.com/ they sell rebuilt units.
Check price and exactly what they need.
