Old 03-26-2008, 04:16 PM
JJames3 JJames3 is offline
Plugs and Cables
Good day All.
1. How do I (pull violently?) the plug cables off the 4.3 Vortec FI? (some have hex-shaped boots)
2. I plan to fit Pulstar plugs - any comments?
cheers.
Old 03-26-2008, 06:13 PM
old_master's Avatar
Advisor/Moderator
Re: Plugs and Cables
Gently twist and pull simultaneously. Use silicone dielectric grease in the boot when re-installing to prevent that next time.
Use AC Delco plugs ONLY! 4.3L's are very fussy!
Old 03-26-2008, 07:51 PM
Thanks for the feedback.
Canadian Tire says the OEMs are 'Coil on plug' and want $200 to fit my new ones (the guy looked like he didn't know too much?). There is a strange hex rubber boot on some of the plugs? (It is a 2005 model)
Due to the price of gas I have already purchased the Pulstar plugs ($150) so, unless I am going to damage something, I wish to proceed.
Old 03-27-2008, 04:03 PM
old_master's Avatar
Advisor/Moderator
The 4.3L plug wires run from the distributor cap to the plugs, only one ignition coil. $50.00 MAX! Save yourself a LOT of money, and headaches, use the AC plugs that the engine was designed to use. You will not get better performance using anything else, the only "damage" will be to your wallet.
Old 03-27-2008, 05:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As Old master says stay with the Ac-Delco plugs the good Ac delco book calls for.
Anything else and you will have a lot of engine running problems that can led to engine or cat damage and is a big .
MT
Old 03-27-2008, 05:54 PM
Thanks Guys,
I will try to send them back.
Old 03-27-2008, 08:44 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
That is a good wise decision.
Good luck
MT
MT
