Old 03-26-2008, 10:50 AM
spivey8 spivey8 is offline
Send a message via Yahoo to spivey8
Re: a/c cold on passenger and hot on driver
i have this same problem with the cold on pass, and warm on driver side
97 gtp with manual hvac
plus if you set the deforst on, you can hear the air but nothing comes out, but if you switch it to deforst/floor then you can feel some coming out the deforst and alot out the floor?
Old 03-26-2008, 11:11 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Your post has been moved from the old thread raised. In other words a new thread. Please try to follow our guidelines for posting in old threads at the link below.
Click here
To start check the HVAC accessory vacuum line that runs from the supercharger, along the firewall and by the battery/main fuse box and make sure it is not leaking, damaged or disconnected for your vent control issue.
For uneven AC cooling between driver and passenger side check the refrigerant charge at the low side port and make sure it is in specs based on the ambient temperature.
Timeslip 08/12/06
AF Community Guidelines
Old 03-26-2008, 11:17 AM
lol my bad, as of now all the 134 has leaked out, so if i fix that problem the uneven warm/cold will be fixed
Old 03-26-2008, 11:29 AM
BNaylor's Avatar
In most cases yes. But in your case you may have to run a leak detector test to see why all the R134a has leaked out. The compressor seal is a common problem.
Timeslip 08/12/06
Old 05-06-2008, 06:59 PM
Rocket1964 Rocket1964 is offline
I had the same problem. It ended up I needed a recharge. Same thing as you need. The problem occurs though when they have to check the whole system and find out you have leaks or need parts replaced. It can get expensive. 700.00 for me to ge mine up and cooling again.
