Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 03-26-2008, 06:51 AM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
95 Town Car Intake
Hey guys, I noticed that my intake is leaking on the front drivers side kinda by/under the thermostant housing. I know its the gasket, but my question is do I have to replace the intake as well?
Thanks..
Bryan
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 03-26-2008, 10:29 AM
danielsatur danielsatur is offline
Re: 95 Town Car Intake
I would replaced the thermostat,gasket,and use a good sealent,
Permatex black is made for a Intake.
MCGIVER
Old 03-26-2008, 11:20 AM
Towncar's Avatar
Towncar Towncar is offline
Hi Bryan.
1st, do you have the upgraded Intake Manifold with the Aluminum front coolant crossover, or the factory installed Manifold with the composite front crossover?
If you still have the factory 100% composite manifold, the leak you see now might be a fine crack developing in the front coolant crossover.
-Steven
1996 Town Car, Cartier
Old 03-26-2008, 01:44 PM
Kitt1993's Avatar
Hey Steve. It is solid cast aluminum. Not plastic.
The President,
Lucky Number 5
Old 03-26-2008, 02:28 PM
Towncar's Avatar
I'm pretty sure mine has an O-ring seal there. If you inspect & find good smooth castings, a new o-ring should do the trick.
If your castings are bad, you might be able to fortify the seal with some goop as mentioned previously.
-Steven
