Old 03-26-2008, 04:24 AM
KEFLON KEFLON is offline
1/4 scale stuff?
Hi guys
Im making a 1/4 scale interior from scratch and I was wondering if any 1 knew where I can get 1/4 scale decals, pe components, resin accessories for example steeringing wheel etc....
thks in advanced
Old 03-26-2008, 03:51 PM
jaykay640 jaykay640 is offline
Re: 1/4 scale stuff?
1/4? Really? What car?
Never heard of stuff you can buy. This is rather a case of full scratch building!
It's big enough to do that and i wouldn't even know what to photoetch there! The needles in the dials maybe :-)
Old 03-28-2008, 06:15 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
You can try searching for quarter scale RC stuff. However, those usually have limited (if any) interior detail . . .
Worth a shot though as ya never know what kind of after market stuff is being produced. . .
Good luck. . .
Chuck
Old 03-28-2008, 10:09 AM
Thks for the help
Its for an interior im desiging for my fianl degree project, the interior is for a next gen MERC CLE 4 door coupe with suicide rear doors
I think Ill have to scratch built everything
the majority of it is being made from automtive clay
progress so far, ive done my shoulder in so I have had to stop for a few days
if u got any ideas, let us know
thks
Old 03-28-2008, 06:33 PM
All right...the scale was too obvious. I knew it... :-) Which college are you from?
Seriously.....aftermarket stuff is absolutely "no go" in a design project unless it's really small bits. I hope you don't consider putting an aftermarket part for something as important as a steering wheel in your model!?
Before worrying about little bits and bobs to add, focus on getting the proportions and surfaces right. If they are wrong they'll distract from the details you put in.
How much time do you have left to build the model? Good luck with it!
Old 03-31-2008, 01:02 PM
CrazyPhantom CrazyPhantom is offline
Send a message via AIM to CrazyPhantom
/\ /\ /\ I agree. I'm assuming you have a hell of a lot more experience in doing what you are doing there, and I am assuming that is the rough beginnings, but it appears there that the proportioning of that interior need a lot of work before the smaller details go into it. I cannot wait to see how that comes out. Your building the body from scratch as well?
Keep us updated.
Old 04-07-2008, 08:11 PM
Progress!
Been resurfacing and balancing the entire model, but still tonns to do hope to finish surfacing and balancing in a weeks time.
Seats are been built using rapid prototyping in about 2-3weeks time,
all the little details are being lazer cut from plastic card, Almost finished drawing them up!
Dials and instrument panel will be lazer etched so all the details will be visible!
im planning on using leathers (v thin) bmf and flocking to simulate a real interior. an a little paint here and there
BTW I never planned to use aftermarket parts just wanted to see whats out there.
Also Im at Coventry Uni and ive got till end of may to finish!
Thks for support
Old 04-08-2008, 03:41 PM
All right:-)
Looks like you have a busy schedule ahead of you. Good luck with progress and with adding those materials on top of the clay. Making the leather stick on it ( especially on the more complicated surfaces ) will be tricky at best. I did it over yellow foam on a model and a lot of tension was necessary to get the wrinkles out.
One possibility you should consider is using a paint like Nextel Suede Coating
http://www.nextel-coating.com/nextel...lt.asp?lng=eng
You can spray it through a standard airbrush ( the real size type that's used to spray 1:1 cars ) and get a very nice fabric like surface. ( A lot like flocking but with a more even surface ). It's not cheap though and you can't buy it at a DIY market....
The "faux fabrics" spray cans by Scalemotorsport are probably the same thing and even easier to use but you have less choice for colours.
Looking forward to see more progress :-)
