Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 03-25-2008, 07:39 PM
newfdude newfdude is offline
Unhappy engine missfiring
i have 01 escape with a 3.o it has a missfire at idleoff idle around1200 to 1500 rpm its ok i checked for codes none found for missfires i also checked compressionin engine all well within specs around150 to 160psi no vacuum leaks i just installed this engine its an 04 engine in a 01 escape orignal engine was low on compression causing bad miss and low power any help would be great thanks
Old 03-25-2008, 11:57 PM
Davescort97 Davescort97 is offline
Escort guy
Re: engine missfiring
Have you replaced the spark plugs and wires? That would make it misfire.
Old 03-29-2008, 03:56 PM
Unhappy Re: engine missfiring
yes i replaced with new plugs she has coil on plug system i checked for vacuum leaks with carb spray and propane no leaks found then i unpluged one coil at at a time in the front of the engine only one made a change it was #5 the other no change in engine also no codes found in ecm at all a also cleaned mass air flow senser drove on hiway drives good lots of power only runs bad at idle missing please help thanks
Old 03-29-2008, 08:59 PM
rhandwor rhandwor is offline
I would look at the connection to the plug are any of them loose. Some coil on plug type have a short wire between the plug and coil if this is so ohm each one of these. You can try a light which goes on the plug and the other end plugs into the coil. If you watch closely you can see the problem.
An injector with a bad mixture will usually show up on the plug. Each injector should make a change on the engine. Use a stethoscope and listen to each injector.
Is their any to richen the mixture up with starting fluid if it calms down you are not running rich enough fuel mixture. If this is the case try a big bottle of injector in the gas tank.
Old 03-30-2008, 10:14 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Does this happen all the time? Does it matter if it is hot or cold?
Old 03-30-2008, 03:55 PM
yes it happens all the time hot or cold
Old 04-02-2008, 07:20 PM
found the problem two connecters #4 and #5 were crossed making it missfire pluged them in the right coil no missfire works great now thanks
Old 04-03-2008, 08:28 PM
highlandlake highlandlake is offline
Good news! Must be awesome to drive it again normally.
Now - do you think maybe someone did that as a prank?
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 06-12-2008, 09:23 PM
MyNeoN95 MyNeoN95 is offline
HOW DID YOU CHECK FOR VACUUM LEAKS WITH CARB SPRAY AND PROPANE? WHAT'S THE PROCEDURE? tHANKS
Old 06-14-2008, 05:56 PM
I spray along the edges of the intake manifold,around fuel injectors and other areas for vacuum leaks. The engine will smooth out where a leak is located.
Old 06-17-2008, 04:36 PM
claspilljm claspilljm is offline
I am wondering if there is anyone that can help me - I have a 2002 4x2 Escape 3.0L Duratex V6 with a check engine light that keeps coming on. I've had the vehicle to the Ford Service Center 9 times for the same problem since September 2007 and the last time (a week ago) it was in, they said it was giving a code P0351. They reset the check engine light and said if it happens again they will try replacing all the spark plugs and see if that fixes the problem. This suggestion is based on a Technical Service Bulletin (05-11-01 MIL on with multiple coil primary circuit) they received from a Ford Tech.
In an attempt to educate myself with the basics, I think I've learned this is a misfire, possibly in the #1 spark plug (any confirmation of this would be really helpful!). The #1 spark plug and #1 Cyl Ign Coil were replaced on 9/26/07, which was my 3rd visit to the dealership for same problem. Basically, as I would roll to a stop, the car would shudder and feel like it was going to die and then the check engine light would come on. This happened on 9/17/07, 9/24/07, 9/26/07, 10/2/07, 10/4/07, 10/9/07, 11/26/07, 6/3/08 and 6/15/08.
I have an appointment to go in on Thursday and am trying to figure out if it's really necessary to replace all the spark plugs or if they should start with replacing the one they've already replaced.
I've also been reading about another problem that causes the check engine light to come on - a DPFE sensor. I'm not sure what this is or if this could be the cause of my error P0351.
Any suggestions or tips would be most appreciated - I'm about at the end of my "let's try this" rope. Thank you!
Old 01-24-2009, 08:46 AM
fulltrottlels7 fulltrottlels7 is offline
i hate missfiring problem from ford cars...... well to replace everything like plugs and coil ts not hard to do that,just u have the tool to remove it and also ford cleaning the injectors by ur self just remove it and buy paint thinner and put all the injectors a can and fill it by paint thinner and wait for 1 hour.....then return it to ur engine and put all the new plugs and coil...then will see what will happen... to remove the check engine just remove the battery terminal and wait for 10 mins then return it.......... i really really hate ford that have missfire problem......
Old 01-24-2009, 04:57 PM
I think you should check the compression as some of these engines need a valve job to correct the problem. A bad injector can also cause a mis as well as a bad wiring connection. Ohm the wires from the computer to the coil as well as the injector. They are not spending the time to find the problem.
Old 01-25-2009, 12:35 AM
actually i already experience that kind of problem i check everything even the compression of the engine is perfect.. the problem is if the engine is cold and im going to start it the idle is very rough and if u going to accelerate theres no power.... if the temp. of the engine is reach half in the gauge it will idle smooth and run perfect... i already change everything including the whole intake system..... i think i need go to church and pray for that car...
Old 01-25-2009, 07:58 AM
Ohm the temperature sensor if the temperature sensor for the computer reads the wrong temperature its going to run much to lean until the engine warms up. This won't set a code as nothing is really showing up bad. Sometimes they get scaled and you can remove it and clean it with steel wool and this is all thats wrong.
If you have a scanner read the temperature the computer thinks the engine is running. When first starting check.
http://www.kemparts.com/TechTalk/tt13.asp This gives temperature and various ohm readings.
