Limiter
so, noob question from someone whos had a vr4 fo0r almost a year now :P
Do we have a rev limiter? im pretty sure jason said we did, but i cant remember. If so, does it sound alot slower than a normal limiter(like one on a SRT-4)? Basically im trying to figure out if im hitting the limiter at High RPMs, or Fuel cut under high boost. My data logger is showing no knock, but i jus wanna b sure. Thanks
'93 3000gt VR-4
170k, 27k on JDM motor MBC @ 14.5 psi Datalogger Intake T-Pros Downpipe Gutted Pre Cats Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs Audio Sony Deck Eclipse 6x8 2 ways in the back Clarion Kevlar cone Component System in the front 2 Alpine Type S 10 inch DVc Subs 1 Audiobahn 10 inch DVC D Jones Series One 800 Watt Jensen amp and a soundstream 300 watt 4 ch to the speakers And still under 4000 lbs w/ me in the car ![]() |
Re: Limiter
I believe it is at 7300 rpms, at least thats what it was on my n/a and it was kind of slow when it kicked in
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Re: Limiter
Go start your car, let it warm up a little, then hold the clutch in and floor it. You'll hear the limiter.
![]() I think it sounds kinda quick, at least on my car. I have a bad habit of hitting it if I run 2nd all the way out.
Re: Limiter
Jason oh and yes it does have a limiter on it! |
Re: Limiter
The DOHC's definitely have a limiter at around 7250, but you can go higher if you miss a shift or something. I've seen over 8400 rpms on my stealth when I missed a shift (recorded by a s-afc).
94 Dodge Stealth TT 94 Dodge Stealth TT, pearl yellow, for sale 93 3000GT VR4, stock, for sale, red 96 3000GT Spyder SL, black, stock, might sell 97 3000GT VR4: stock, for sale, red 92 Galant VR4: TBE, bunch of crap 95 Montero SR: run stuff over vehicle |
Re: Limiter
Yeah its right around 6300 limiter. My car loves second gear for some reason and pulls all the way to the limiter.
Re: Limiter
Just a quick note, hitting the rev limiter will not help you any. If it be a race for speed or anything. Plus its a good way to do serious damange to other parts of your car....please only act stupid if you are ready to wrench more then needed on your car.
Coop |
Re: Limiter
Hitting the limiter will not necessarily do damage. The limiter is to prevent damage. My brother has sat there and held his old Cherokee's gas pedal to the floor trying to get out of a mud hole and it was just bouncing off the limiter for a good 30 seconds. No damage.
Re: Limiter
i've only hit my limiter once. I dont like to make a habit out of it on a 15 year old vehicle. There's not really any need to take it that high anyways since i have stock turbos.
Re: Limiter
so at what RPM level would it be considered "over revving" ur motor if redline is at 7k but limiter is at 7250?
'93 3000gt VR-4
Re: Limiter
An overrev happens usually on a misshift. For instance you go to shift to 4th and hit 2nd instead. The ECU can't keep up with that and will sweep past the rev limiter.
Re: Limiter
my point was, as brian and i know, most oil pumps and pick ups are not up to snuff. This will limit the amount of oil the engine needs at that RPM. Limit it enough and kaboom.
Coop |
Re: Limiter
what kinda horsepower will a stock GT sl make on a dyno? just asking cuz on 3si i read a mod'd gt will only make 190 to the wheels..so curious as to what a stock one will make....cuz i would always read our cars having 222..so i wanna kno why its so low lol |
Re: Limiter
222 is severely overrated. In reality max they make at the crank stock is 210. They only dyno 170 to the wheels in stock form. Theres not many na mods you can do to it to get significant gains.
Re: Limiter
Smooth! Welcome to the forum.
Never bring show to a go fight.
And a TT conversion brewing.. |
