Old 03-25-2008, 12:42 AM
mike2020q mike2020q is offline
Exclamation Driver Side Vent blowing Outside Air
Hi,
Even I put my Air to Recycle, still my Driver side vent blowing outside air. How can I fix it. When A/C or Heat is on this vent will have 80% outside with 20% conditioned air (Conditioned means: Cold or Hot, depends on the season). I also noticed I can't move the knob in this vent to the right.
I got Civc / 1991 / LX / 1.5L
Can you help please?
Thanks,
Mike
Old 03-25-2008, 12:24 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Re: Driver Side Vent blowing Outside Air
Originally Posted by mike2020q
Hi,
Thanks,
Mike
If the knob doesnt move at all, the cable attached to it may be stuck/broke.
You may want to pop off that little knob, then pop off the little cover plate. There is a single phillips screw holding it in. Get to this screw from underneith the dash.
How stuck is the knob? Does it move at all? or completly jammed?
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 03-25-2008, 01:31 PM
Thanks Jeff for your answer: Here is some extra info that you requested >>>
It does move up to the middle position. So I guss I can say it isn't total stuck.
Old 03-25-2008, 09:50 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Up to the middle position!? Dont they move side to side? Mine blows whatever it feels like it..the linkage is all attached but it doesnt move the flapper in the duct..so sometimes the air has enough power to blow it closed and I get all a/c, and then when I get driving the outside air pushes it back.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-26-2008, 11:59 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Mine really doesn't blow anything if it is closed, but will blow in outside air.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-26-2008, 03:37 PM
Yes you are right. It moves to side....till middle position.
Old 03-26-2008, 03:41 PM
FrodoGT's Avatar
My crx vent did that after I took the dash out and put it back in..could never figure out what went wrong with it, it still closed..but the lever just didnt move all the way.
Current project:
Rio Red 91 hatch.
Old 04-07-2008, 08:57 PM
Alright I think I know whats wrong...
Sounds like the actual cable that attaches to the vent unit has came loose, it's only clipped in by a very small plastic clip. This clip holds the outer housing of the cable tight while the inside cable pulls/retracts to open the vent.
My heater controls have the same symptom and it's because the clip is half broke (provides enough tension only to switch to the defrost setting) any other settings the knob becomes tight and will not slide.
If you can figure out a way to secure that cable without buying a new unit let me know, I've had this problem for like 6 years, but I only summer drive my car so I dont really need anything other than defrost
Hope this helps you!
||JEFF| |
Old 04-07-2008, 11:28 PM
FrodoGT's Avatar
Well the vent on the drivers side is a little different. It doesnt use those plastic clips. Mine is firmly mounted and attached right, the arm even moves and all. But the door just doesnt move with it.
Current project:
Rio Red 91 hatch.
