| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Installing Neons Help
Hi, I currently own a 19999 firebird and I am installing flex LED type neon lights under my car. I have the knowledge to install them but I just had a wiring question. Currently I only have 2 inside LED lights that shine onto the passenger and drivers lap and legs. These LEDS are hooked up by a ground nut on the chassis and running the hot to a light wire for the shifter. It seems to work fine and I can even fade it with the variable pot but I am looking to install something more now. I am aiming to install 8 LED neon tubes(4 underglow, 4 wheel well) on my car with a controller that can change the actions of the neons. I plan on grounding it to the same part of the chassis but as for the hot I wanted to know rather this would be to much power to put through such a small wire, the wire that is used for the shifter light is only about 20 gauge. The reason I'm using the shifter light is kind of obvious, I could run it straight to the battery but it would ruin the purpose of being able to turn on my neons when my headlights come on.
Re: Installing Neons Help
you'd probably get a lot more responses if you left out what the lights were Without knowing the wattage of the lights, there's nothing we can add. I wouldn't go over 4 amps on a 20 guage wire. Either switch it with a relay, or rework the circuit with bigger gauge, if the amps of the lights equals more than that
life begins at 10psi of boost Three turbo'd motorcycles and counting.
Oh I'm not sue of the wattage but that helped me a lot, a relay is an excellent idea, I don't know why I didn't think of that. Thanks!!
