Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-24-2008, 10:55 AM
glc4122 glc4122 is offline
low coolant light
yes i have a 97 gp and the low coolant light comes on and goes off at different times. it seem to go on when im on the interstate driving at 65 mph and goes off when i get off interstate. i checked coolant level and it's always down a little. what could be the problem?
Old 03-24-2008, 01:10 PM
A-Dog A-Dog is offline
Re: low coolant light
Have the coolant collection reservoir checked. I had the same problem, and my collection area was described as "nasty" by the repair shop. they cleaned it out and never saw the problem again.
Old 03-24-2008, 06:01 PM
thanks for the info,do you mean the antifreeze recover bottle on driver side of engine?
Old 03-24-2008, 07:36 PM
Yes I believe so. Altough I can't be certain, as I'm basing my thoughts on my repair ticket, which said said "coolant recovery reservoir"
Maybe some of the more knowledgable folks around here can confirm
Old 03-24-2008, 08:03 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
ok, i am kind of confused here you say your low coolant light comes on and when you check the reservior the coolant is low...sounds like its doing its job when you check the coolant how low is it?
the reason it may be going on and off is maybe you hit a bump, turn a corner etc and it causes the coolant to go below the mark.
you may want to check you UIM/LIM and see if you need one. assuming that your car is a '97 and if you have no knowledge of it ever being changed...you prolly need to repair them.
Old 03-24-2008, 08:37 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
I am having the same problem, but mine is full and I checked the radiator and its full too. My light is on when I first start the car then when it warms up to normal temp it shuts off, any ideas guys
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 03-25-2008, 12:16 PM
Brent S Brent S is offline
I too have a similar problem on my 99 GTP. My light was coming on, so at 90k miles, I replaced the sensor and replaced all coolant. The light still came on for a day. I then unplugged the connector, and carefully bent the contacts (ever so slightly) to possible ensure a better connection. This worked for 15k miles. Now, the light is coming on again, and going off after 20 min. of driving. I tried messing w/ the connector again, but it doesn't appear to solve anything. What's really strange is that the light goes OFF, when the connector is unplugged. What kind of sensor logic is that????
Old 07-08-2008, 06:25 PM
I thought I would update this post:
I finally got around to flushing out the coolant on my '99 GTP. I removed the sensor (1 year old), and it had the infamous brown sludge on the little brass pin (electrode). After a rather time-consuming flush, refill, flush again, etc....and cleaning the sensor electrode (twice), the light still comes on sometimes.
Therefore, I am coming to the conclusion that Dexcool does suck (like many people claim) and that the Low Coolant sensor is a poor design because it seems to be causing many problems as the Dexcool sludge collects on the sensor. I will probably just unplug the connector, put some plastic on it (for protection), and simply drive the car without that particular sensor.
It doesn't seem so important, anyway.
Old 07-08-2008, 08:29 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I disagree to a point. Reason is people that switched to anti-freeze like Prestone Extended Life and canned the Dex-cool are having low coolant sensor issues too and the bad part is no resolution short of disconnecting the connector.
Also, if you are losing coolant you may have bad UIM/supercharger or LIM gaskets which could affect the low coolant indication.
Timeslip 08/12/06
AF Community Guidelines
Old 07-09-2008, 02:13 AM
wlkjr's Avatar
wlkjr wlkjr is offline
My manifold gaskets didn't fail until I had 306,000 miles on the car all with Dexcool. Car now has 346,000 miles and still using Dexcool. I think the gasket design was the bigger problem. Those same people who always blame Dexcool also probably are the ones who shout the BS about Fram filters.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 07-09-2008, 08:39 AM
Oh, ok. I thought in a previous BNaylor, you said people switched to Prestone and it solved the problem.
Either way, the sensor design is probably deficient, because it seems to attract whatever amount of "sludge" that exists in the system, and allows it to deposit right on the little electrode. I guess it needs a prestine coolant system to function correctly.
I don't think I'm losing any coolant, although I have never seen the coolant lever to the very very top of the radiator filler neck when the engine's cold. Ever. No matter how many times I fill the radiator, the system seems to always stabilize with the coolant level 2-3 inches below the very top of the neck, and the recovery tank just "absorbs" the couple ounces that I keep putting in.
Well, the light is off (for now), and I'm putting this issue lower on the priority list.
Old 07-09-2008, 09:19 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Many people switched to the other brand simply because it's cheaper. The only issue with Dex-cool is GM's claim that it lasted 5 years/ 150k miles. It should be changed/flushed earlier than that (3years/50k max), and if it's not, that is what leads to sludge buildup. Most if not all of GM's supposed Dex-Cool issues are the fault of junk OEM plastic framed gaskets and shoddy engineering (plastic coolant elbows, EGR stovepipe, 3800 upper plenums, etc...)
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-06-2008, 08:10 AM
bigstakz bigstakz is offline
So can anyone tell me what will make the light flash on and off steadily?
2001 Pontiac Grand Prix SE 3.1 V6
2000 Chrysler Concorde LXi
Old 12-06-2008, 08:14 AM
BNaylor's Avatar
Sorry but please start a new post. See our guidelines below. This thread has been closed.
Old Thread Guidelines
Timeslip 08/12/06
Closed Thread
