Old 03-24-2008, 11:01 AM
albee9 albee9 is offline
Angry 93, Vandura won't start
I posted this in the GMC forums and did not get much help there
My problem started when I started getting black smoke from the exhaust so i thought change the spark plugs which were very fowled just to get it home .
but still black smoke so i changed the fuel injectors still hard to start so to make a long story short .
I have replaced : the spark plugs,the wires distributor,rotor, the ignition coil,EGR solenoid ,and fuel injectors and it still won't start .
I'm getting spark and fuel and compression .
Please help
thank you for your time
Old 03-24-2008, 04:11 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 93, Vandura won't start
Black smoke=running rich. Pull a spark plug and see if there's gas on it (there probably will be). Check the Engine Coolant Temp sensor. If the computer is seeing too low a temperature, it will put more gas in because less gas evaporates for combustion at lower temperatures. Did you try cranking it in flood-clear mode (WOT)? That may get it to start if it is flooding.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-24-2008, 05:44 PM
I'm sorry but did I miss some thing ???
I know what the black smoke means .
I am now tiring to get it to start after i changed the injectors i got it to run and did a code check that's when i changed the EGR solenoid.
now today when tried to start it it truns over but dies . and yes i will let everyone know what the fix is once i get going.
thank you
Old 03-25-2008, 04:44 PM
Well the saga continues I checked the timing and that seems to be right on
