Old 03-24-2008, 01:29 AM
elnakman elnakman is offline
Smile Chevy Bose System
new guy here,
i have a 06 silverado w/ the bose system. i have an aftermarket stereo, its a jvc dvd player. i wanna know if i can hook up the subwwoofer to this stereo. i have all the speakers hooked up, but not the sub. i kinda wanna put back the original stereo on, but this jvc sounds good, however missing the low frequency. any help will help, thanks.
Old 03-24-2008, 04:17 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Chevy Bose System
integrating aftermarket and OEM stuff is challenging at best. The factory sub must have some type of amp it's connected to.
Old 03-25-2008, 03:29 AM
so i need a seperate amp to run my factory sub??? in that cse i should might as well run a whole set-up, amps and sub w/ box. thanks
Old 03-25-2008, 06:04 PM
Audio Guy
often times, thatg is the easiest (or only) real option. The amp for the sub will not be very powerful, assuming you can tap into it .... and the amp for all the other speakers is built into the headunit. Even more sinister is the fact that all too many OEM systems these days have a built-in EQ circuit designed to tune the factory stuff. There are only 2 or 3 boxes like the JL cleansweep that can really flatten it, and they are NOT cheap.
