Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-23-2008, 08:36 PM
Dan Cook Dan Cook is offline
Exclamation 95 Mustang 3.8 V6 Running real rough all of a sudden.
We have a 95 Mustang with a 3.8L V6. We have had the car over a year and it has run very nice up until now. It has just over 100K miles on it. Recently it started missing and running very rough. I changed the gas filter and the air filter but it still runs rough. The engine sounds like it is very lean when you first start it (It rattles badly then clears right up). Going down the road it misses and cuts in and out. The oil pressure is normal and the temp is normal. Any suggestions. Thanks in advance.
Old 03-23-2008, 09:08 PM
goretex goretex is offline
Re: 95 Mustang 3.8 V6 Running real rough all of a sudden.
i am not that familar with the 3.8, but if it has a distributor, check the cap for carbon tracking. if there is rep;ace the cap and rotor
Old 03-24-2008, 09:38 AM
351wStang's Avatar
351wStang 351wStang is offline
Sounds like ignition to me. What do the plugs look like? lean? Could be a faulty fpr.
Have you checked to make sure the plug boots are up on the plugs good? None of the wires are burnt?
1969 Cougar
357w & TKO - 475hp
Old 03-27-2008, 08:07 PM
carlos80 carlos80 is offline
This vehicle has no distributor. How long has it been since a tune up. Is the check engine light on? If it is have the codes pulled to isolate which cylinder(s) have the miss
