Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 03-23-2008, 05:28 PM
badtazboy's Avatar
badtazboy badtazboy is offline
Oil Pressure
Hello all little help here.
I started my 99 Bravada this morning and the motor sounded like it was going to throw a rod.
Checked the oil, full and clean.
Noticed that my oil gauge shot straight up to 40 and stayed there. Started again later in the day, same thing but this time the gauge would jump to 60 when revved.
I’m guessing it’s the oil pump.?
Old 03-23-2008, 05:39 PM
inafogg inafogg is offline
Re: Oil Pressure
hello,sounds like oil pressure is ok!!40 psi @ idle 60 when reving.why are u thinking oil pump
Old 03-23-2008, 06:14 PM
badtazboy's Avatar
Re: Oil Pressure
Previously it would drop when idle now it sits at 40.
Old 03-23-2008, 10:23 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Oil Pressure
One of the lifters would peck cold in my '97 in the winter until I did the winter oil change, then it would be quiet.
Old 03-24-2008, 02:11 PM
badtazboy's Avatar
Re: Oil Pressure
Just did an oil change, made no difference. Spoke to a dealer and a motor shop both said the same thing, oil change.
Any other suggestions?
Also noticed that radiator was low. Filled up ran for awhile and noticed water dripping from the muffler. The oil when I changed it was normal (not brown cloudy).
Leaking head?
Old 03-24-2008, 06:11 PM
Re: Oil Pressure
have you or can u put a pressure gauge on to see what the pressure is??or do u think dash gauge is correct???
Old 03-25-2008, 07:58 AM
AF - Advisor
Re: Oil Pressure
Check the coolant level later and see if it's still dropping...the exhaust gasses condense water in cold weather.
Like you mention, watch your oil too.
Have you had any transmission work done lately? A loose converter will bang and knock to beat the band.
Old 03-25-2008, 03:03 PM
old_master's Avatar
Advisor/Moderator
Re: Oil Pressure
Originally Posted by badtazboy
...Also noticed that radiator was low. Filled up ran for awhile and noticed water dripping from the muffler.
A byproduct of the catalytic converter is water, perfectly normal to see it drip.
Oil pressure spike could be due to the oil pressure relief valve sticking. The oil filter and the oil filter adapter must be removed to replace it, quick, easy, cheap job.
Coolant in the oil will destroy the oils ability to lubricate causing a knock. Pressure test the cooling system. A very common problem with the 4.3L engine is a leaking lower intake manifold gasket. If it leaks, it can leak coolant into the oil, into a combustion chamber, or leak externally. Hope this helps.
Old 03-25-2008, 08:35 PM
badtazboy's Avatar
Re: Oil Pressure
Knocking fixed … drained out a quart of oil and added a quart of Lucas, drove for 5 miles and knocking went away.
As for the water … it’s just not a drip it actually leaves a pretty substantial size puddle.
Am going to flush the radiator this weekend and run a sealant through.
You Need To Be Smarter Than The Machinery You Operate.
