Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 03-23-2008, 03:29 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
1995 intrepid transmission removal
ok im working on removing the dead transmisison in a 95 intrepid right now
i finally got the 4 upper bellhousing bolts out after much cursing and skin scraping
dropped the exhaust as low as it will go in the front since they dont come out all the way due to the subframe being too narrow
i need to know a few things ASAP
the trans mount: should i remove the single acrossways throguh bolt in the mount assembly, or remove the 4 small bolts that hold the mount to the crossmember ? looks like thje crossmemberneeds to be removed as well in order for the trans to come back and down out of there
wiring harness plugs: only found one such plug and its on the pass side
is there another wiring plug anywhere i cant see ?
thats pretty much it right now
thanks for anything D
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 03-23-2008, 11:53 PM
AWP9521 AWP9521 is offline
Re: 1995 intrepid transmission removal
Make sure the Transmission is supported, then remove the single long bolt that holds the mount to the Transmission, then remove the 4 bolts that holds the Transmission crossmember to the subframe to get it out of the way for removal.
The Transmission wiring is connected to a main connector block on the passenger side strut tower, and should be the only wiring to worry about but look it all over real closely just in case before yanking it.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 03-24-2008, 09:22 AM
oh theres one main harness plug ? ok D
what about the shift cable to the trans case ?
is there a bolt to remove or is it clipped to the case ?
lmao @ your signature quote ahahahaa
thanks!
Old 03-24-2008, 05:23 PM
The cable housing should be clipped to the case or to a bracket on the case, squeezing a couple of tabs should be needed to remove it, the cable end should have a grommet on it where it attaches to the shift arm and that should pop off by prying the cable end off the arm, you may need to remove the cooler lines (Should be removed anyhow to replace the tranny) to get better access to the shifter cable.
Old 03-26-2008, 01:01 AM
ok the cable housing to the trans case was eay, one bolt and it holds a big clamp down
simple D
the only thing i never figured out was the trans wiring harness
it has no main plug away from the trans, i had to unplug every little thingsd from the trans itself to get the trans out, the harness doesnt unplug from the main car harness
i could not find such a plug to separate the trans harness from the rest of the car harness
hmm
it just goes endlessly up into the engine compartment from the trans
going to go pick up a replacement trans from the junkyard today sometime
tranny mount is junk completely broken apart so getting a new one of those too haha
no wonder it had a clunk noise
thanks!
