Go Back   Automotive Forums Car Chat > Nissan > Nissan Cima | Nissan President | Infiniti Q45
Old 02-27-2003, 06:38 PM
marcelq45 marcelq45 is offline
Question remote programming instructions?
Does anybody know how to program remote for 95 q45? One day both my remotes stopped working. It was a very cold day, may be that's why.
Please help out...
Old 03-05-2003, 09:50 AM
maxnix's Avatar
maxnix maxnix is offline
Batteries?
Have you replaced the batteries? Usually available at Home Depot check-out lines.
Reprogram Key Fob
J30, 1994-1996 Q45, 1994-1996 G20
To reprogram (enter new ID) key fob (keyless remote controller)
follow the steps.
1. Close all doors and lock all doors
2. From the door switch unlock the trunk.
3. Insert and remove the key from the ignition key cylinder six times within 10 seconds.
Note:
-Key should be withdrawn from ignition key cylinder completely each time.
-At this time, the new ID code is entered and original (previous) ID codes are erased.
4. Manually unlock and lock the driver side door
5. Push any button on the new remote controller once. If there is only one remote controller skip step 6.
6. Additional ID code entry: -Repeat step 4 and 5
7. END.
Note:
-If you need to activate more than two additional new remote controllers, repeat the procedure on step 6 "Additional ID code entry" for each new remote controller. Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Brian
1995 Q45 & Q45t 2000 Q45
Old 09-01-2004, 02:08 AM
spotco2 spotco2 is offline
Banned
Re: remote programming instructions?
Here is the correct programming procedure
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2479233788
Old 09-14-2004, 04:15 PM
maxnix's Avatar
Do not pay for this!
This is BS! The quoted procedure above by me is from a factory TSB.
Brian
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
Mazda keyless remote programing instructions vantur 323/Protegé/Familia/Etude/Allegro 1 01-31-2004 11:45 PM
keyless remote programming instructions Nevil General Discussion 2 09-13-2003 09:19 AM
Keyless Entry Remote Programming Instructions studioedit Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-16-2003 03:01 PM
1998 Keyless Remote Programming Instructions boss2003 Sebring | Sebring Coupe | Convertible 1 07-25-2003 04:16 PM
