Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 03-23-2008, 06:43 AM
kwg kwg is offline
voltage drop at coil
hello everyone...i have a 67 chevelle big block that will not fire....i have 12 volts at the coil, butr when i turn the engine over it drops to 9 volts. i tried running a wire directly from the battery to the coil and it starts fine...my problem is from the battery to the coil...need help.
thanks,
ken
Old 03-23-2008, 03:22 PM
72chevelleOhio 72chevelleOhio is offline
Re: voltage drop at coil
Did you upgrade to an MSD system?
If you try to use the resistor wire for points systems to run MSD you will get a drop exactly like that...
If thats the case you need a new ignition power wire to the coil...
