Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 03-22-2008, 11:04 PM
aaronlogan aaronlogan is offline
Brakes soft then hard then none
if i use the brakes with light pressure they work slam on the brakes pedal goes hard will not stop.. If I sit still at stop light peddal drops away and starts to roll.. anybody have any fixes for this one THANKS ALOT
Old 03-25-2008, 04:53 PM
Benzman Benzman is offline
Re: Brakes soft then hard then none
If you haven't already, you should make sure that you are full on brake fluid and do not have any leaks.
If no leaks and full, then I would suspect the ABS control module. You can probably get one from a junkyard, just make sure that they are identical before purchasing.
Old 03-26-2008, 09:22 AM
DurangoDave DurangoDave is offline
Classic symptoms of bad master cylinder seals.
Dave
Westminster, MD USA
Old 03-26-2008, 05:49 PM
Isn't the master cylinder part of the ABS control unit on this year?
Old 03-26-2008, 06:12 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
Master cylinder seals.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 03-26-2008, 10:02 PM
jpb53 jpb53 is offline
Didn't say he had ABS and didn't give the year so guess away.
Old 03-27-2008, 12:05 AM
You're right. I somehow put a year in my head. Thanks.
Old 03-27-2008, 03:31 PM
wayneo69 wayneo69 is offline
check to make sure the brake line is not seaping or leaking behind the gas tank near where it mates to the hose, also check the wheel cylinders make sure they are not wet inside the boots. if they check out ok slap a master cylinder on it
