Leaking windshield washer bottle 2005 Avalanche
How do you get the windshield washer bottle out to check for leaks or to replace the pump. I took the battery and its holder out as well as a plastic fastener from the wheel well that holds the bottom of the bottle. But I could not get it out. It leaks when you fill it up but stops when the level gets below the seal of the pump. The pump works so is the seal just bad? And can you get just the seal. I can't see every thing very well without getting the bottle out.
Thanks Jeff |
Re: Leaking windshield washer bottle 2005 Avalanche
i am not shure on how to get the bottle out. you will need to find all the bolts holding it in then probly drop it out the bottom of the truck. you can use gasket sealer if its just a bad gasket on the pump. or you may need to get a replacement pump. if the pottle is cracked. you may be able to use a plastick welder, on it.
