Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 03-22-2008, 08:35 PM
gorgepr gorgepr is offline
Question any turbo lt1 here???
does any of you guys have convert an lt1 to turbo?? if any of you have could you be so kind and tell me wich size of turbine you used and how big are the injectors?? thanks
Old 03-23-2008, 11:09 AM
poormillionaire2 poormillionaire2 is offline
Re: any turbo lt1 here???
Hmmm...I don't think there are many guys with LT1's on here, and not too many people with a turbo on their f-body. Injector size depends a lot on how much boost you are running. And turbine size depends on how much power you want to get out of the car. But I hope you plan on rebuilding the motor with forged internals, or else you will be limited by how much boost you can run on the stock motor.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 03-23-2008, 12:53 PM
im was thinking on boosting 5 to 7 pounds, for now cuz the buget is very limited, and I want to to this cuz a friend of mine offered me a turbine fully rebuild for 350 dolars and he told me it will work on his car (350 buick engine) or on mine, cuz on my town guys are a lot more in to imports and the only two with v8s are him and me also he didnt need it anymore cuz hes car is already turbo and he dont want to mess up the setup so he offered to me and I dont want to make a lot of power for now but since the oportunity is there Ill like to take advantege of it
Old 03-23-2008, 01:13 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
if you're on a budget you're better off going with bolt-on mods instead of turbos.
turbo setups are pretty complicated, and shouldn't be attempted unless you know them well. and for 5-7psi of boost, you can get more power than that with bolt-ons for less money and less headache.
Seatbelts Saved My Life
Old 03-23-2008, 01:21 PM
Yeah, turbos can be a pain to install, depending on where you mount it. I've heard the rear-mount STS kits aren't as complicated as ones that are traditionally mounted in the engine bay.
On a budget, I wouldn't do it. Its going to cost you more than you think. I say, stick with bolt-ons, a cam, and possibly some head work.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 03-23-2008, 01:24 PM
this are the number that I have in mind
turbine $350
fuel pump $120
intercooler free
boost gauge $40
blow off free
injectors 30lbs $150
this are the things that I already have almost on my hand I think I found at a cheap price also the setup and the tubes the guy thats selling me the turbine will to it for free cuz he and I work that way
Old 03-23-2008, 01:25 PM
yea I wanna do it a rear mount its a lot more easy
Old 03-23-2008, 01:31 PM
remote turbos FTL.
they're crap, don't believe anyone that says otherwise.
Old 03-23-2008, 01:39 PM
Rear-mounts are better than dealing with a routing turbo-manifolds. There is nothing wrong with rear-mounts. Sure, the boost has to travel further and you may lose some pressure in the tubing, but its better than nothing.
Personally, I would go with a supercharger. But that's just me.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 03-23-2008, 01:44 PM
bolt ons > rear-mount turbo.
seriously. they're a waste of time and money.
Old 03-23-2008, 09:45 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
what do you have to back up your statement that remote mount turbo's suck?
id have to do some google searching to support this statement, and if its really necessary i will, but i have seen dyno testing, before and after the install, that showed significant gains.
why should i ignore before and after dyno results because you say they suck?
not trying to be a huge prick, just curious.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-13-2008, 05:13 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Hardly. Check out the forced induction section of LS1tech.com. Zombie is running 10s in the summertime at Las Vegas(100+ temps and DA over 5500'). I guess that sucks for a rearmount turbo. Many others are running good times with rearmounts. Its tougher to setup then a front mount but they can work very well.
Seriously, if you want to go turbo, you're going to spend a lot of money. No real way around it. Budget turbo's are not easy and you will have to do the vast majority of the work.
Just to let you know, I have a built engine(LS1) and 60# injectors, twin 225lph intake fuel pump, bigger feed line, stock feed line is now return line and an aftermarket fuel rails & fuel pressure regulator. On top of that, I have an intercooler(recommend getting one on any Forced Induction kit) and alcohol-water injection. I have a 70mm turbo on it pushing 10psi(street) and about 650rwhp.
Now if you want to run 5-7psi, you can get away with smaller injectors and a single inline external pump(although with LT1 edit just get the biggest high impedence injectors you can get and tune for them because you'll get (just say for instance) 38# injectors but when you start wanting more boost, you'll end up getting 50# injectors or like me 60#ers...just figured I'd save you some $$$ in the future ). Make sure whoever tunes your car, they know what they are doing. Tune is a must and vital to the survival of your engine, built or stock.
Just trust me, I was that way 4 years ago...and now look at my car. Basically a street legal race car. I'm
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
