Old 03-22-2008, 12:49 AM
mossrl mossrl is offline
S-10 intermittent starting problems
I have an s-10, 2.8L TBI that will runs great for days or weeks and then it will crank but won't start after it's turn off. I did a tune-up, rebuilt TBI, replaced fuel pump and filter. There is no spray, but fuel is going to the TBI. Also replaced the coil and cleaned every ground I could find. Can anyone please help.
Old 03-22-2008, 09:31 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: S-10 intermittent starting problems
What year?
On the older ones you have to have spark from ign and coil before it will triger the injectors.
Does it have good spark when no start?
Is the no start temp related like hot or cold or just after you shut it down hot?
What is the fuel pressure when no start?
MT
Old 03-23-2008, 04:09 AM
Sorry it's a1992. But Ithink I've might have it. Ireplaced the ignition modual and it started right up. I'll drive it for few days and see what happens.
Old 03-23-2008, 08:49 AM
MT-2500's Avatar
AF - Advisor
Thumbs up Re: S-10 intermittent starting problems
Thanks for posting back how it went.
Sounds like you found the problem.
Good luck
MT
MT
Old 03-23-2008, 02:52 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
had the exact same problem on my brothers 92 s-10 4.3L Z and yes they need to have ignition to run the TBI injectors
on his it ended up being the big pink wire from the distr to the coil it was broken inside the wire insulation to where you couldnt tell it and it would sometimes not start
finally figured it out one day messing with it while it was running
probably is a really common problme on these
i save this wire from junk ones now
dealer has it for 25 bucks though
includes the smaller white wire next to it too
and they are only a few inches long
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
