Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-21-2008, 06:46 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
Transmission flush manual
I know how to change the gear oil for the transfer case and rear differential. You drain out of the bottom plug and then fill through the plug halfway up. And for that I am going to be using Redline Heavyweight Shockproof Gear oil.
I read somewhere that the transfer case takes .5quarts, the rear diff. takes .9quarts, and the tranny awd(2.3quarts) Fwd(2.1) quarts.
For the transmission I have read mostly that using BG synchroshift is the way to go. I have never done a tranny flush on my car or any manual though. If anyone can tell me step by step how to on the transmission or has a site that does that would be sweet.
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 03-22-2008, 02:55 PM
Re: Transmission flush manual
I am guessing that it is a drain plug and fill plug like the rear diff and xfer case but does anyone know for sure????
SOLD
'97 GSX
Old 03-22-2008, 03:25 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
yeah, their is a drain plug and a fill plug... i did it on a 2g GS 420A never on a 4g63... but i will be soon... you remove the fill plug, then pull the drain plug so it will empty... and someone else chime in about fluids because i will be doing mine, and cant decide between redline shockproof or BG Syncro shift...
edit: i have also heard good things about royal purple gear oil... anyone?
Old 03-22-2008, 08:40 PM
anybody else done it? Silvr?
SOLD
'97 GSX
Old 03-22-2008, 08:50 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
All the places gear oil is used, you fill until the fluid comes out the fill plug hole. That's why it is critical to have the car on a level surface. I use Redline shockproof in the t-case and rear end. The tranny was a mix of pennzoil synchromesh and redline. Gives benefits of both. Synchromesh by itself is too thin for adequate protection. I can't remember the mix. I think it was 2 bottles of redline, the rest synchromesh. I found this out on tuners somewhere recommended by shepherd himself.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-22-2008, 09:08 PM
But how exactly do you do it on a manual? What/where are the plugs etc.
SOLD
'97 GSX
Old 03-22-2008, 09:12 PM
Testiklees
That is for a manual. The fill on the t-case is right at the front just below the oil pan. The drain is on bottom pointing directly at the ground. You will see it. Both fill and drain on the tranny are on the far left side. Want pics from a 1G?
Tim
1990 Talon AWD
PTE SCM5031
Old 03-22-2008, 09:31 PM
Testiklees
Here they are anyway. Went out with my phone:
Tranny drain/fill. Drain hard to see but gives you an idea:
http://i11.photobucket.com/albums/a1...0322082215.jpg
T-case fill:
http://i11.photobucket.com/albums/a1...0322082214.jpg
Tranny drain:
http://i11.photobucket.com/albums/a1...322082215a.jpg
T-case drain:
http://i11.photobucket.com/albums/a1...322082215b.jpg
Tim
1990 Talon AWD
PTE SCM5031
Old 03-23-2008, 10:05 PM
awesome pics man! Those are very good pictures for a camera phone. I can't wait for the damn snow to melt ahhhhh It just snowed another 3 or 4 inches this morning!!!!
SOLD
'97 GSX
Old 03-23-2008, 11:23 PM
Testiklees
That was just on normal quality and low resolution. I hope they help you when the snow clears.
I was thinking today about this thread while working on my car and thought about what I used to fill them up. I found laying around here a large syringe type thing that is used for mixing and measuring oil and gas for 2-cycle engines. Attached it to a long hose and it makes it pretty easy.
Tim
1990 Talon AWD
PTE SCM5031
Old 03-24-2008, 09:36 AM
Oh yeah I suppose I will need to get one of those.. Where can you get them and how much do they cost?
SOLD
'97 GSX
Old 03-24-2008, 05:21 PM
Testiklees
I don't know. I just found it laying around. Any parts store I assume. Doesn't seem like a specialty part or anything.
Tim
1990 Talon AWD
PTE SCM5031
Old 04-06-2008, 09:29 PM
I did the tranny fluid and rear diff today. For the tranny I used amsoil synthetic and for the rear diff I used redline shockproof. The tranny shifts noticeably easier now with the amsoil I noticed it quite a bit.
SOLD
'97 GSX
