Go Back   Automotive Forums Car Chat > Buick > Regal
Old 03-21-2008, 06:04 PM
hakebros hakebros is offline
cat converter want code 420 gone
Hi guys,
several months ago, we had performance issues with a 2003 Regal GS. Mechanic changed the fuel pump but the prob was a faulty cat converter. We changed that out and all is fine, really. Performance & mpg is great but that darn code 420 keeps popping up about every other week. We clear it out yet it comes back. Is there a way to fool the computer to not give this code?
Old 03-21-2008, 07:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: cat converter want code 420 gone
Was the convertor replaced GM or aftermarket? Common to get this DTC with aftermarket CATs. You can use a post CAT 02 simulator or get a re-programmed PCM module that will inhibit the DTC.
Timeslip 08/12/06
AF Community Guidelines
Old 05-02-2008, 04:09 PM
thanks, can you go into more detail on a "post CAT O2 simulator"
Old 05-03-2008, 08:52 AM
BNaylor's Avatar
All a 02 simulator does is report normal activity that the CAT converter is operating properly and prevents the P0420 DTC. It plugs into the sensor wiring harness and used in lieu of the real sensor. See link below.
Click here
What brand CAT converter was installed?
Timeslip 08/12/06
