Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 03-21-2008, 05:54 PM
JimElvis JimElvis is offline
Send a message via Skype™ to JimElvis
Gas mileage gong down hill
My '04 Envoy 5.3's mileage was 21 mpg a year ago. In the last few months it's been going down hill. I'm now getting 17-18. I did a tune-up, plugs and wires, 50k miles, that didn't help. Any suggestion?
Boy, with all the problems I see here, I should feel lucky that this is my only issue.opcorn:
Old 05-29-2008, 04:29 PM
Electromek Electromek is offline
Send a message via Yahoo to Electromek
Re: Gas mileage gong down hill
Do you have any codes, espaecially transmission codes?
It almost sounds like the transmission clutch control (TCC) is not working? If that be the case you will not shift into overdrive and will be in drive at best. In drive most vehicles have a gear ratio of 1:1. In overdrive it is 0.66:1. Do the math you will be using about 1/3 more gas. If I am correct you will have to drop the transmission to change the coil.
If you find a decent shop like I did for my old van it was $300 for the tranny in/out and $50 for a coil and filter change. The dealer will probably want closer to $1000.
There is also a few sensors that would throw the mileage out the window. Such as MAP, TPS, etc.
I guess you need to answer the code question before we could proceed?
Old 05-30-2008, 11:09 AM
wardak33 wardak33 is offline
try changing the o2 sensors, fuel filter, air filter and cleaning the throttle body. they're simple fixes that can save you a couple MPG's. i would do that before messing with the transmission.
2002 Oldsmobile Bravada AWD w/ SmartTrak
1999 Mitsubishi Galant 2.4L I4
Old 05-30-2008, 09:49 PM
I wouldn't touch a thing including any tune up stuff as suggested by others until the code question is answered.
Old 05-30-2008, 10:04 PM
lamehonda's Avatar
lamehonda lamehonda is offline
In my experience, it is often the O2 sensor. It'll seriously screw with your mileage. I had a honda that went from 35 mpg to 20 mpg just because the O2 sensor was bad.
1987 Honda Accord LX-Dead
1999 Honda Accord EX-L 5 sp-Sold
2006 Subaru WRX Wagon 5sp-Sold
2005 Nissan Frontier ext cab 4x4 4.0L-Sold
2006 Kawasaki Ninja 500r-Sold
2004 Yamaha FZ1 Silver/Black- Sold
2008 Mazdaspeed 3-In the driveway
