Old 03-21-2008, 04:18 PM
curtybigguy's Avatar
curtybigguy curtybigguy is offline
snappin CV joints
I have a little problem i have a 96 chevy 1500 with a 6 inch suspension lift and 33 inch tires i have broke 3 CV joints on the drivers side and i was not even driving it hard they just seem to snap as soon as i start having fun haha. is there an aftermarket cv out there to solve my problem?
Old 03-21-2008, 04:33 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: snappin CV joints
I have never seen any. You might want to compare yours to a 3/4 ton and see if the ends are the same. That would at least give you more time until they break. You may need to lower the front differential. I know little about IFS compared to solid axles, but I have seen trucks with a 4" lift with the diff lowered, so I'd assume that such a high angle is a common problem with them. Depending on the "fun" you're having, they do make kits to convert the front to a solid axle.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-05-2008, 06:39 PM
I think i solved my problem. All i had to do was that after closer inspection the torsion bar was cranked right up. so we loosed that off and it dropped the front of the truck two inches. i took it out and had some "fun" and all things are good now
Old 09-25-2009, 12:40 AM
Ros981500's Avatar
Ros981500 Ros981500 is offline
Depending on the left that was installed most of them come with a 2 inch spacer for the driver side. that goes between the diff and the cv shaft so you don't have that issue.
