Old 03-21-2008, 12:53 PM
dirtydx dirtydx is offline
emission test result bs??
I went to a shop to get a new catalytic converter..
they installed it but found that it wasn't working... they phoned me and left a message wondering what they wanted me to do next.. I never got the message, instead I just showed up near the end of the day figuring everything was OK. I think this pissed them off. Anyways he said he had a second cat in stock, and that he could weld it in while i waited... I heard no grinding or welding while i waited for an hour. A mechanic came out and gave me these results from his gas bench:
HC 67 PPM
CO .02%
NOX 3 PPM
the CO and NOX look suspicious.
I went to a Drive Clean centre next week, they gave me these results:
HC 146 PPM
CO .55%
NO 58 PPM
which failed me on the HC and CO. I went back to the shop, and got them to test it on their gas bench again... He revved my engine very high for atleast 5 minutes.. then came out and said "cat failed".
I figure they are messing with me. But I just wanted to know what you guys thought of their gas bench results before I try to get a refund. (I paid them because they said everying was OK).
"I just threw away a lifetime of guilt-free sex and floor seats to every sporting event in Madison Square Garden. So, please, a little respect, for I am Costanza, Lord of the Idiots."
Old 03-21-2008, 04:05 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: emission test result bs??
Well, if he put a second cat in...as in he replaced the first, then its a bolt in affair. If he ADDED one then Id be suspicious. Also if you fail once, you dont just keep adding cats till you pass.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-24-2008, 03:15 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Sounds iffy to me. That's a pretty big difference between test's where there shouldn't be that much variation.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
