| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Here's a dumb question: Why a blue spark in a car engine why not white?
Re: why not????? white?
huh? i dont get it. people dont decide what color the spark is, but if your wondering why it happens to be that way, blue is hotter than white. so why not blue?
blue is hotter than orange.....but the sun isn't blue....HOW?
ask a stupid question, get a stupid answer.
Seatbelts Saved My Life
thank you
So... yes, the spark in a spark plug is a higher temperature than the sun! And there are blue stars.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
yup. interestingly enough, the light wave spectrum is similar to the temp color spectrum...coincidence? i think not.
I'm not sure if this laser actually exists, but I'm pretty sure it does, and I'm pretty sure it's blue. |
A laser beam does not have a temperature. It has energy and can cause things to heat up. It's color is insignificant. carbon dioxide laser beams are more or less invisible, but pack a hell of a wallop...
And i dont understand what you are asking. The surface of the sun is ~6000*C. the corona is much hotter, at about a million degrees. The insides of the sun is at hundreds of millions of degrees. Good for nuclear fusion. As things get hotter, they go from the red end of the spectrum to the blue end. slideways: its not similar, it's directly related.
Oook. I see what you did there.
