ok I have a 93 metro xfi with a no spark problem
I was driving the car awhile back and one morning she just died on me with no warning and the problem then is still the same today I replaced the distributor, cap, rotor, coil, spark plugs, wires, voltage rectifier and I still have no spark at all I dont understand this issue and i am at my witts end on this has anyone else experienced this problem? if so how do i fix my lil car i miss her and her gas mileage please someone help point me in a direction to where the problem might be
seeker of parts |
Re: 93 metro xfi no spark issues
Wow, there have been an unusual number of timing belt failures lately.
This is where I'd peek first, If I were you. Another member had a great idea: if you just remove your top two timing belt cover bolts, you can peel it back enough to glance down at the cam sprocket to see if there's anything around it. -MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car 1993 Geo Metro - Accident 1991 Caprice 9c1 - Destroyed
really thinkin it might be the timing belt? how do i pull codes from the ecu???
seeker of parts |
You won't get a code with a broken timing belt. Do what caprice said. It will only take you 5 minutes.
...yeah it's pretty painless, but just for future reference; there is a raised fuse slot in the box under the dash on the driver side. Stick a fuse in that raised slot, and turn the ignition on and the check engine light (CEL) will flash the code(s) for you.
-MechanicMatt
