Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-20-2008, 05:19 PM
Billie46 Billie46 is offline
coolant in oil
I have 95 toyota pick up 2.4 4x2 head gasket was ok sent head to shop was checked out ok , what do I check next?? Could I use J Bweld two part apoxgy to repair timing gear gear housing?
Last edited by Billie46; 03-21-2008 at 11:56 AM. Reason: Looking for quick and cheap repair
Old 03-20-2008, 09:32 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: coolant in oil
Well, if it's not the HG, the only other way that I can think of for oil and coolant to mix is if the Timing Chain is so worn it wore a hole thru the TC cover.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 06-02-2008, 09:19 PM
JudoJohn JudoJohn is offline
Re: coolant in oil
could be a cracked head.
