Old 03-20-2008, 04:20 PM
jjcoop jjcoop is offline
Cruise control switch
How do i remove the airbag cover to gain access to cruise control switch on my 02 grand am. The switch is broken. I have looked for screws on the outside of the steering wheel but see nothing. So do i have to remove the cover? If so do i just pull on it...after disconnecting the neg?
Old 03-20-2008, 04:50 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Cruise control switch
There are screws that go through from the back (that is to say front of the car) of the steering wheel. Usually you must rotate the steering wheel to access them. Don't forget to disable the airbags!
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-20-2008, 06:15 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF jjcoop.
YEah I would pull the neg. battery terminal and pull the air bag fuse.
You'll need a #30 torx bit to remove the 2 screws.
Is your cruise on/off button broken ?
1999 Grand Am SS 3.4 OHV
