Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-20-2008, 04:05 PM
volsmd99 volsmd99 is offline
Need help identifying these oil leaks
I posted pictures to photobucket so hopefully these should work. I've been losing a lot of oil lately. Two of the leaks look like they are close to the transaxle. I can't figure out the source for the oil that is sitting on the air hose to the intercooler.
http://s283.photobucket.com/albums/k...99/Oil%20Leak/
1995 Mitsubishi Eclipse GSX
Old 03-21-2008, 01:20 PM
steviek's Avatar
steviek steviek is offline
Re: Need help identifying these oil leaks
I wish I knew more about the 1g's cause those pics are pretty good and you deserve some help. So I figure maybe you will get some help from this bump and someone who knows them better (thor maybe?). I know that sometimes when the turbo is on its way out you can get oil into the intercooler pipes (happened on my buddies t25. Anyways I suppose it could be coming from inside the pipe and leaking out at that junction but it isn't that lilkely. But it sure is easy to check. Just take off one of those clamps and look to see if the inside of the intercooler pipes is coated with oil
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-21-2008, 02:10 PM
Thanks for the reply. My car is actually a 2g with a turbo that's about two years old. It was replaced by the dealer after an accident. As far as the intercooler pipe, I was thinking that just air flowed through it. I guess that's why I was a little confused about how the oil ended up there given I can't see any real source.
As far as the other two leaks. I'm wondering if the first is a rear main seal. The second one appears to be coming from the transaxle but once again I would expect transmission fluid instead of engine oil.
Please correct me if Im wrong.
Any help is appreciated.
Old 03-21-2008, 03:00 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Oil leak 2 looks like your t-case yoke seal is leaking. Get it fixed under the recall at a mitsu dealer.
They all seem to be on the rear side of the engine. One shows oil covering the flywheel cover (1a). See if you can tell what fluid it is. Tranny, t-case or engine oil? Could be oil pan too. Rear main is also a spot but that might make your clutch slip or chatter as it coats the flywheel/clutch disk.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-22-2008, 08:46 AM
I didn't realize there was a recall on the yoke seal for the 2Gs. I thought it was just the transfer case.
Old 03-22-2008, 11:40 AM
Testiklees
If as a result of yoke seal leaking that the t-case goes bad, they have to replace it for free.
Tim
1990 Talon AWD
PTE SCM5031
Old 04-11-2008, 02:19 PM
So I called my local dealer and they said that could not cover the cost of the recall. I also called mitsubishi motors and they said the same thing. Does anyone know if this true?
thanks
Old 04-11-2008, 03:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
thanks
By LAW they're required to cover the cost of the recall, thus being a recall. Stick it to them
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-11-2008, 03:13 PM
I forgot to mention that I have a 95 eclipse and the car was inspected once when the recall first came out. From the threads, it seems like this should not matter, but I want to make sure before I pick a fight.
Old 04-12-2008, 07:49 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Was the recal for a specific year/trim or was it for all 2Gs?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
