Old 03-20-2008, 04:17 PM
mannasugar mannasugar is offline
starter, battery voltage
The battery has 11.7 volts.
The starter is receiving 10.5 volts.
The starter has new brushes.
10.5 volts should be plenty to turn the engine over.
All the starter will do is click.
What other component of the starter or solenoid could be at fault?
How do I test the starter relay on the fender?
Old 03-21-2008, 12:52 AM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: starter, battery voltage
your battery is classified as dead. anything below 12.25 has a 0 to 25 percent charge. so in orhter words you need to charger your battery back to the specified volts i.e. 12.5 to 12.6 at least and if your battery cant hold a charge then its boned. if your battery wont evne charge or isnt charging your alternator is dead. so the onyl fault is user error. theres not probably but a dead battery.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 03-21-2008, 12:53 AM
rockwood84 rockwood84 is offline
take the starter off and test it using a pair of jumper cables. if the bendix ain't kicking over then all its gonna do is click. i bought a new starter from autozone put it on all i had was a click. changed the selinoid still had only a click.took the starter off the crown and it started up. tsted the new starter by using a pair of jumper cables and the damn bendix wasn't kicking over.took it back 35 miles to autozone and put it on the counter hard enough to leave a big dent in the counter and cussed all of the dudes behind the counter out and made them bench test the 2nd new starter to make sure it worked before i left. so check the bendix it should kick all the way to the end as the gear turns
