Headlight/foglight colored bulbs
Well im currently using the ultra-white Silverstar bulbs for my headlights and foglights, the foglights seem like a waste because the blowup ALL the time.. and as far as i can tell there not even that white compared to the newer cars, but really i've seen a couple Gp's (1997+) mines a 99, and they have like ultra blue or just bluer headlights/foglights or even green for the matter. What bulbs are they using? do you need mods to have them? i currently already have an amp for my neon underglow kit, so will getting these blue lights require more amplifying? also just got new headlights so there very shiny/clear. Any info would be great!
Thanks in advance, Kyle. |
Re: Headlight/foglight colored bulbs
in my opinion, the blue/greenish bulbs are junk. if you want a decent bulb...i would look into the Sylvania Silverstars.
if you really wanna go all out, and wanna spend $120.00, check this out. i have this kit on my GTX, and it is flat out AWESOME. very very bright, and pretty much plug and play. i see it is out of stock right now, but i'm sure they will get a shipment soon....
There is actually a bulb out there that is better than the outdated Sylvania Ultra's. No doubt they are good bulbs but there are better for only a little more ( or less from the right place). Eurodezigns Ultra. They are $79 from the company but some folks have them on ebay for a little less. Also for anyone reading this, search that site for the Sylvania's as well. Not trying to promote anything just figured everyone could save a little here and there. But the eurodezigns bulbs are a 6000k xenon halogen that produces a whiter light than the sylvania and also puts out more lumens. Also DOT approved which means a lot to me. The blue lights shouldn't need any amplifying. They are nothing more than a halogen bulb with xenon gas inside. If you get them, make sure they are DOT approved and that the voltage matches the voltage on the stock bulbs. If they don't you could burn up your wires. But you could upgrade your wiring harness and get more light out of the bulbs.
'01 Regal GS |
Hey guys, I have 94 cavailer with pliot headlight bulbs (hid lookalike) and i love them. I have had the car for two years,and only had to replace them once. They are just as bright as most hid kits that you can buy. I only pay about 20-30 dollars for a pair. I had the silverstar lights and they dont compare.I have a great color and i can see alot better, in town and on the highway. The best bang for your buck, Thats just my opinion.
As far as i can tell these should work for my car: http://cgi.ebay.ca/97-03-Pontiac-Gra...QQcmdZViewItem Description:
To be honest theres alot of choices for xenon lights off of ebay, very few need kits for them to work, anyone ever tried these bulbs i listed above?
They are all similar on ebay of the xenon bulbs. As long as you just get a xenon bulb, you will need to do nothing except swap the bulbs out. Between the two listed, personally I would choose eurodezigns due to them being dot approved. Obviously you are looking for blue bulbs and you may get pulled over at some point for them (cops are assholes!). You could get a ticket for having one that is not approved but having one that is and having some sort of proof on you could save you some time and money. Also the 8500k bulbs may not put out as much light as you want. Check out a color temperature scale and you will see after like 5500k, lumens (light output) is lost. And the salesman that said sylvania and the euro ultra are the same is wrong and obviously knew nothing about them. The euro's have a truer white and also more light output.
'01 Regal GS |
The PCM is located inside the airbox (the box containing the air filter). I don't remember exactly how to get to bacause I put on a ram air intake which required removing the airbox, but I think you just unclip two clips holding it together and pull out the filter and you should see the pcm at that point. It is helpful to unclamp the intake hose and remove it because it allows you to completely remove the smaller side of the airbox. Just make sure you watch out for the IAT sensor (located on the intake tube).
'01 Regal GS |
The spark control unit under the packs has been known to go bad on the 3800's so you might want to check that out.
Anyways back on topic, i've ordered the blue Euro design bulbs, ill post a before and after picture of what the bulbs look like. For a rough idea watch this video
http://www.youtube.com/watch?v=Bzpel...eature=related Thanks for the replies guys, made a new thread on my cylinder #3 misfire. |
