Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-20-2008, 12:54 PM
bpddaddy bpddaddy is offline
From one problem to the next...
I'm back everyone. My lifter chatter on my 2001 5.3L has gone but in its place I now have an engine knock which is constant through all RPM's. It's a very, very faint knock and can only be heard while inside the truck. Let me give you history so you can tell me where to go next.
- Plugs changed - wires not (lifter noise begins)
- 2 Oil changes, last one with full synthetic
- Marvel Mystery added (no change)
- Sea Foam added to clean injectors
- New wires added (lifter noise disappears)
Now the engine knock. Manual suggests fuel, plugs, ignition are places to begin. No check engine lights.
Truck has 106k on the engine and has been well taken care of. I'm almost at the point of repairing this knock, whatever it is and telling someone to give me $10k and it's yours.
What are your suggestions?
Old 03-20-2008, 04:30 PM
Re: From one problem to the next...
Just went out this afternoon and did a better test and listen. The knock is still faint, but I place my ear on the air filter housing and the knock is very well heard from there. If you stand back and listen to the engine, you can't hear the sound - even used a stethoscope on the block and still couldn't hear it. Therefore, it must be coming from the fuel system (injectors, throttle body) or a spark plug has another poor connection.
By the way, the lifter chatter is back - I'm going the fuel route next.
Old 03-20-2008, 11:14 PM
Just picked up more spark plugs after visiting the local Zone. 2 behind the counter say it's the plugs. I failed to mention that I dropped one of the plugs before installing. That might be the problem.
Will report back later.
Old 03-21-2008, 08:24 AM
jonnik jonnik is offline
What brand of plugs and wires did you use? Have you replaced the dist. cap and rotor? I've found that it's always best to stick with AC-Delco.
Old 03-21-2008, 02:51 PM
AC Delco, AC Delco, AC Delco
Yep, it was the plugs. AC-Delco 4195 are in now and everything working great!.
Now, For Sale 2001 Chevy Tahoe, 106k miles, Moonroof, LT Autoride, $42,000 brand new, front and rear AC, brand new Yokohama Geolander tires (4k miles), Front and Rear Diff fluid changed, transfer case and transmission fluid changed, Mobil One Full Synthetic ran, new plugs, wires, New pads and rotors, fuel filter (4k miles). New intermediate shaft. All for $10,500 or $10,000.
Just completed a meguire 3 step cleaner, polish, wax and seal. I drove it off the lot myself, so One Owner!
Come and get. Plus, it's a California Car! - No Rust!
