Old 03-20-2008, 09:42 AM
ljinindy ljinindy is offline
Directional Signal
I have a 2002 Alero and recently my directionals have stopped working. Last night I had to turn the hazards on and off and then they started working. Obviously there is a loose connection somewhere, but I have no idea as to where to start looking. Any suggestions?
Old 03-20-2008, 12:18 PM
tarasalero tarasalero is offline
Re: Directional Signal
there was a recall on the alero's signals because, well they just don't work. if you take it into a GM dealer they will fix it for you. mine did that last year, and even the hazards were intermitent. it's really lame, but call up aGM dealer and they do it for free because of the stupid recall, or at least that's what they did for my 01 alero. best wishes.
Old 03-30-2008, 01:05 PM
TRSTACIE TRSTACIE is offline
Do you have a copy of this recall. MY turn signal works intermidently off and on it works. Sometimes it just goes off and then back on, anyone know if this is part of the recall? and what the issue is??
thanks
Old 03-31-2008, 07:47 AM
jrozanc's Avatar
jrozanc jrozanc is offline
Just an FYI on the recall. We had an 2000 GLS alero. When I contacted a dealership and gave them our VIN, I was informed that our car was not covered under the recall. The reason? The recall pertains to certain vehicles made at a certain factory. Our VIN/car was not made at the factory that the recall was called aganist. Even though we had the same problem they wanted to charge us for the replacement. Food for thought....
Old 04-01-2008, 07:33 AM
83cutlass 83cutlass is offline
Its not exactly a recall, but GM will fix it for free for a while.
This special policy covers the condition for a period of 10 years or 150,000 miles.
You car must be within these VIN breaks. Last 8 of VIN
1999 Oldsmobile Cutlass X6332770 to X6343584
1999 Oldsmobile Alero XC002988 to XC435868
2000 Oldsmobile Alero YC000007 to YC372282
2001 Oldsmobile Alero 1C242103 to 1C286657
2002 Oldsmobile Alero 2C100001 to 2C321946
Old 04-06-2008, 05:23 PM
Iflylow's Avatar
Iflylow Iflylow is offline
It is GM bulletin 04098A. If they won't do it for you, the bulletin tells what parts you need, and shows how to do it. Replacing the hazard switch will fix both the hazard lights and the turn signals, since the flasher for the turn signals is built into the hazard switch.
