Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-20-2008, 07:07 AM
ghalacsy ghalacsy is offline
91 grand marquis
Hey all. I have a 91 gm and every 30 minutes it chimes 5 sets of 5, just like at start up. it has me baffled as to what is causing it. any help would be appreciated.
Thanks
Guy
Old 03-20-2008, 05:37 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 91 grand marquis
Check to see if the air bag light is working. If the bulb is blown, it will cause that. Here is AlldataPro's definition.
Tone Generator
The air bag readiness lamp is the prime means of determining the air bag system condition. However, a series of five sets of five tones will be heard if the readiness lamp is out and a fault occurs in the system. This also means that the Supplemental Air Bag System is in need of service. The tone pattern will repeat periodically until the fault and lamp outage are serviced. Unless serviced, the Supplemental Air Bag Restraint System may not function properly in the event of an accident.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-26-2008, 05:48 AM
now that i replaced the bulb the airbag light blinks non stop. at least it doesn't beep anymore.
Old 03-28-2008, 03:05 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Here's a site that will explain everything you need to know about airbag lights and resetting the system.
http://www.airbagsolutions.com/
On most vehicles, the airbag light should come on for @6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident.
The flashing light on your car is telling the answer you need. On some vehicles, the light is flashing a two digit code. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing.
http://www.airbagsolutions.com/light.aspx
This website gives you the procedure for diagnosing and resetting airbag lights. See if your car is listed here.
http://www.airbagsolutions.com/vehicles_list.aspx
Some vehicle manufacturers accommodate systems without a scanner (like Toyota, Lexus, Nissan, Infinity, Honda, Acura, Ford, Lincoln, Mazda & Mercury) and some require a scan tool.
Check out these websites also for more info on airbag systems and the light.
http://blog.airbagsolutions.com/arch...ould-i-do.aspx
http://www.airbagsolutions.com/resources.aspx
Also, you may want to check out this site for information on researching your own vehicle for factory recalls!!!
http://www.airbagsolutions.com/nhtsa.aspx
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
