Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-20-2008, 01:40 AM
aaronh2005 aaronh2005 is offline
Angry chewing up belts!
ok i have a 98 talon, esi, NA/NT, manual trans
this car has been chewin up belts left and right. took it to the shop to replace one belt coming off, but now both are slipping. the first problem is the alt. belt. that one keeps slipping, even though the belt is tight. maybe a pulley is getting stuck? but when they are free (no belt on) they spin fine. the alt is still the original one though. the p/s and a/c belt came off tonight on my way home from work. that one may have come off because of the alt belt coming off though (riped or torn through because of tearing on the alt belt). i have no clue what could cause this. i was thinking maybe crank walk, but i don't have any other problems associated. any help would be greatly appreciated. if you need pics of the set up just let me know and i will post them!
thanks,
a very frustrated talon owner
Old 03-20-2008, 01:50 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: chewing up belts!
The chance of your car crankwalking is like .000000000001%. Have you checked to make sure the crank pulley is still in alignment with the alternator and accessory belts? I had that problem once. The crank pulley wasn't completely aligned and it kept throwing/tearing belts when I would drive it.
95 Talon TSI AWD
97 Eclipse GST
Old 03-20-2008, 06:59 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
+1 for making sure pulley is aliegned. Also make sure there isin't any damage to the pulleys.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-20-2008, 10:36 AM
yeah that was the first thing i checked. all pulleys are in line. the alt pulley has a little bit of chewed up belt on it, but nothing that would cause it to completely throw it off. the shop did say that the alt could be bad because it looked burned up. they said if that happens the pulley on the alt could have some play in it when the engine heated up and got hot. yeah i thought crank walk was a bit of a stretch too, but with the way things are going on this car, i would discount it.
Old 03-20-2008, 10:41 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Do they sqeak? If so, when? When going straight or turning? Hot or cold engine? And pics are never bad.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 03-20-2008, 03:12 PM
Just for good measure, check the bolt that holds the crank pulley on and make sure it's tight. I know the pulleys may "look" in line, but even 1/8 inch off could be throwing belts. I literally had to pull the whole passenger side of the motor apart and get a straight edge before I found out that the pulleys were not aligned. I HOPE that's not your problem because it wasn't fun.
95 Talon TSI AWD
97 Eclipse GST
Old 07-29-2009, 01:05 PM
freddy86 freddy86 is offline
Great Info here guys, first time and new to the forum.
I have a 99 Eclipse that is doing the same thing and in my looking for the cause,I ran accross this TSB
TSB 9837A005 for the 95-99 model eclipse which may include your vehicle. Symptoms include rapid belt wear and/or the throwing of the belt.
Basicly it is a recall for belt misalinment, and provides fixes to the dealership mechanic. This included the non-turbo with and w/o AC. Not for sure but i also think it talked about the turbo models. (i was having my 16 year old read it to me over the phone so i could post this)
The fixes for the dealership mechanic include:
a. replacing the Idler pully (they give the new part number),
b. Check the AC bracket for alignment. TSB indicates a replacement bracket if this is the problem. BTW ..on a search i saw where a cracked AC bracket also caused this issue of belt throwing.
c. Power steering bracket out of alignment which the TSB indicates using 1mm shims to bring back into alignment.
The TSB kept refering to pictures, but the one I downloaded did not have them.
Hope this helps you find and fix your issue. ..Wonder why it wasn't a recall to fix.
Old 08-12-2009, 12:18 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Are any of these pulleys of yours aftermarket ones? I had problems with a civic I had bc it had aftermarket pulleys...chewing up belts all the time...ended up putting the original pulleys back on...
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
